18 years agoIs there a command/pragma/etc that can be placed in the schematic so that I wouldn't have to use the Assignment Editor?
I'm used to having a command called "uniquify" in Design Compiler, which will make unique instances of all entity/arch or modules that it finds in a design. Once that is done, the compiler proceeds as normal. I suppose using the Assignment Editor is basically the same thing, correct?
