9 years agoSynthesis output for multiple driver within one always
Hi, I came across a code snippet and has been boggling my mind quite a bit. The equivalent to the code is below: a is output and x is an internal register always@(posedge clk) begin ...
9 years agoI see.
However, I am not completely clear on this. My understanding of multiple drivers is this: You have a flop. Two signals are driving the input of the flop at the same time - Which cannot be possible. Now, in this code. considering two scenarios by itself. a<= 1; is an unconditional non-blocking statement. This takes place every clock cycle. On the hardware I believe this to be a gnded wire connected to the D input of the flop. if(x==1) a<=0; This would be a mux whose output is driving the input of the D flip flop. Looking at the above two conditions, when x equals one. We have two wires with different values driving the input of the flop. Could you please tell me how different this is from a multiple driver? Although this would make sense if always@(posedge clk) begin a<= 1; if(x==1) a <= 0; end is same as always@(posedge clk) begin if(x==1) a<=0; else a<= 1; end Your help is appreciated. Thanks
