bitstreamer
5 years agosynthesis of synchronous logic in system verilog interfaces
In Quartus, is synchronous processes allowed in system verilog interfaces for synth? I'm seeing messages from quartus indicating that logic signals need an initial value, even when they are assigned as a wire to values that are generated within the interface.
Warning (10030): Net "if_my.signal" has no driver or initial value, using a default initial value '0'
Code in interface:
assign signal = local_generated_signal && logic_interface_signal;
- SyafieqS
Hi Joe,
You may need to refer to below link for details. I believe system verilog also work as verilog where you need to manually assign value to the net.
- bitstreamer
That's the problem, it's not working as synthesizable verilog. A register assignment shouldn't be assigned really. Thanks though.
