aejjeh
7 years agoSynthesis failing when using AOC compiler
I am trying to synthesize an OpenCL kernel. Building for emulation succeeds. When I try to compile for FPGA, the process fails with an error (16045): Instance "X" instantiates undefined entity "Y", a...
- 7 years ago
You can refer to below to see if it resolve.
OpenCL kernels with names longer than 61 characters might fail in the Quartus compiler with an error similar to the following error:
Error (16045): Instance "...|<long_kernel_name>_cra_slave_inst" instantiates
undefined entity "<long_kernel_name>_function_cra_slave" File: <filename> Line:
<linenumber>
https://www.intel.cn/content/www/cn/zh/programmable/documentation/bhg1517418195706.html
HRZ
7 years agoPlease post your full quartus_sh_compile.log file.
