Altera_ForumHonored Contributor12 years agoSynthesis error in VHDL process Hi, I am trying to implement clock synchronizer and clock divider in the following piece of VHDL code. The clocks(clk_rx and clk_tx) should synchronize at the rising and falling edges of 'RX' s...Show More
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
