13 years agosynthesis error 10818
Hi, while working with OpenCores SD card controller ( http://opencores.org/project,sdcard_mass_storage_controller ) I got error 10818 while trying to synthesize this for Cyclone IV (DE2-115). ...
13 years agoHere is an update - although this workaround worked well for the pruned test case, it also works for the "real" code:
always @(posedge clk or posedge rst )
begin
new_bw <=0;
if (rst) begin
m_wr_pnt<=0;
write_cnt<=0;
new_bw <=0;
end
else if (we_m) begin
if (free_bd >0) begin
write_cnt <=~ write_cnt;
m_wr_pnt<=m_wr_pnt+1;
if (!write_cnt) begin //First write indicate source buffer addr
bd_mem<=dat_in_m;
end
else begin //Second write indicate SD card block addr
bd_mem<=dat_in_m;
new_bw <=1;
end
end
end
end but the issue now is - moving new_bw to an 'else' clause requires putting it there several times. It's far from mechanical patch. The pattern of always ... begin
xyz<=0;
if ... if .. if .. then xyz <=1 ...
end is rather frequent in the sdc_controller code. So, although this is a workaround, the resulting code is difficult to understand and VERY prone to errors - if you miss one branch, you'll get a register that holds value longer then 1 clock cycle, which is not what is intended. I still wonder if there is option or way to make Quartus understand this rather simple preposition - a default value on the signal in the always block. So, what about simply removing 'rst' from the always sensitivity list? This is not quite the same function, but if reset is simply a reset there, not cigar pretending to be a reset :-) it may work.
