18 years agoSyntax Error
can anyone tell me whats wrong with this code? :confused:
My device is Family : Cyclone Package : FBGA Pin Out : 256 Speed Grade : 6 Name : EP1C12F256C6 My code: -----------------------------------------------------library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity allT is
port(g, y, r : buffer std_logic(1 to 4);
clk : in std_logic);
end allT;
architecture behav of allT is
signal d, q : std_logic;
signal gL : std_logic_vector(1 to 16);
signal yL : std_logic_vector(1 to 4);
component delay
port(D, clk : in std_logic;
Q : out std_logic);
end component;
begin
process(r, clk, x)
begin
if (clk'event AND clk = '1') then
d <= '1';
case r is
when "0111" =>
g <= "0001";
when others =>
null;
end case;
for gL in 1 to 15 loop
greenL : delay port map (d, clk, q);
gL <= gL + 1;
end loop;
case r is
when "0111" =>
g <= "0000";
when others =>
null;
end case;
case r is
when "0111" =>
y <= "1000";
when others =>
null;
end case;
for yL in 1 to 3 loop
yellowL : delay port map (d, clk, q);
yL <= yL + 1;
end loop;
case r is
when "0111" =>
y <= "0000";
when others =>
null;
end case;
case r is
when "0111" =>
r <= "1011";
when others =>
null;
end case;
end if;
end process;
end behav; ------------------------------------------------------- When i compile this code, i get 4 errors. Error (10500): VHDL syntax error at allT.vhd(35) near text "port"; expecting "(", or "'", or "." Error (10500): VHDL syntax error at allT.vhd(35) near text ";"; expecting ":=", or "<=" Error (10500): VHDL syntax error at allT.vhd(54) near text "port"; expecting "(", or "'", or "." Error (10500): VHDL syntax error at allT.vhd(54) near text ";"; expecting ":=", or "<=" -------------------------------------------------------- i'm new member here, please tell me if i make an illegal act or something wrong in this forum..thanks..:D
