10 years agosyntax error at medias_2.vhd(31) near text "in"; expecting "(",
I've got this error in the following code, what's wrong in it? Thanks in advance. library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_signed.ALL; use IEEE.STD_LOGIC_arith.ALL; ...
10 years ago --- Quote Start --- Theres probably a ( missing near line 31. Also, your problem in your other post is probably because you included std_logic_arith - please delete this library. --- Quote End --- But where in line 31 i put this "("? I've also tried to delete std_logic_arith that was defined in other part of the code, still don't work.
