Altera_ForumHonored Contributor13 years agoSynchronization Chains not detected Hi there, I have clock domain crossing in my design. I use synchronization chains for metastability. In a part of my design I instantiate a custom made dual clock FIFO. After the flow is comple...Show More
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
