18 years agoI still think you have a problem with the simulation. So is the simulated data bus undefined, or high-z?
You did not say which tool you use for simulation. Do you have a correct model for the Cyclone II output buffer? If you see no change in data output when you switch OE on and off, something is wrong with the model or the stimulus... About burst accesses, no Altera controller that I know of uses burst access for SDR SDRAM.
