18 years agoRight, but at the moment the design is that "open" that there are hundreds of useless warnings, which will disappera anyway after additional modules will be included.
Furthermore : I am using the "clock off" - method to dynamically remove parts of a design which I do not need for a certain test to be able to add also Signal Tap Logic and much RAM.
