Jesse
7 years agoSuppress debug messages from Altera simulation IP
I must be missing something really simple here, but I can't figure out how to suppress the insane flood of useless debug messages that comes from Altera simulation IP. For example, this appears in ...
AnandRaj_S_Intel
7 years agoHi,
Are you directly editing the file or you are passing the parameters in modelsim run time?
I have used EMIF example(EMIF arria10 FPGA IP) from quartus 18.1 pro QSYS. but i can't find the parameter enable_debug_info = "true". Can you share more information on tools version and IP used?
But i was able to change other parameters in run time in modelsim using vsim -g INITIAL_RESET_CYCLES=0 -do xxxx.tcl or directly changing it in script file.
Anand
