AEsqu
Contributor
3 years agoSupport for multiple instances?
With Vivado there is not problem to handle this situation:
The main RTL is synthesized in one vqm.
Then a small top level is synthesized with Synplify,
it instantiates the main level t...
sstrell
3 years agoI did read the whole post.
When you simply say something is not working, that doesn't explain what the issue is. And if there are any warning or error messages, that helps someone clue in on what the problem is.
And as far as duplicate naming is concerned, you don't mention that in your original post, so I asked.
