AEsqu
Contributor
3 years agoSupport for multiple instances?
With Vivado there is not problem to handle this situation:
The main RTL is synthesized in one vqm.
Then a small top level is synthesized with Synplify,
it instantiates the main level t...
sstrell
3 years agoWhat exactly "is not working"? Compilation failure? What errors are you getting? Are the two instances of the same block uniquely named? Quartus Standard or Pro? Way more info needed here.
AEsqu
Contributor
3 years agoYou apparently did not read the original post properly.
Please read it again, not just the title.
