Struct type multi-bit port optimized to 1-bit port during mapping
- 3 years ago
The code is fine. It's just this feature only supported in pro version without warning (check image):
Same warnings also appear in standard version (check image):
The synthesis engine of pro version is different compared with standard/lite synthesis engine.
Sheng
For the posted code example, I see only an inappropriate warning in the mapper report. As the technology map viewer clarifies, the pins are connected correctly. I don't see the claimed relation to synthesis engine capabilities. Besides unsubstantiated warnings, do you see any problems in actual design mapping, may be for a less trivial design?
I also don't understand the relation to Quartus Pro. There's effectively no choice between Quartus Standard versus Quartus Pro. Some devices need Quartus Pro, for others Quartus Pro isn't provided, e.g. Cyclone V used by the OP, even if you have the license. I know that Quartus Pro has more support for some new VHDL and SV features.
