Struct type multi-bit port optimized to 1-bit port during mapping
- 3 years ago
The code is fine. It's just this feature only supported in pro version without warning (check image):
Same warnings also appear in standard version (check image):
The synthesis engine of pro version is different compared with standard/lite synthesis engine.
Sheng
It depends on how you have the signal connected in your design. Can you show what this input is being connected to and confirm that bits aren’t getting optimized away?
These signals should not be optimized. I am afraid the tool cannot handle struct type ports.
Please find a simple example attached. You can load the .qpf file in Quartus and run "Compile Design".
Also attached the map.rpt file that includes the mentioned warnings:
; din ; Input ; Warning ; Input port expression (0 bits) is smaller than the input port (2 bits) it drives. Extra input bit(s) "din[1..0]" will be connected to GND. ;
; dout ; Output ; Warning ; Output or bidir port (2 bits) is wider than the port expression (0 bits) it drives; bit(s) "dout[1..0]" have no fanouts ;
