amildm
Contributor
3 years agostruct -> how to add to SignalTap ?
Hi All,
Is it possible to add the struct signals to SignalTap? I did a search for the struct signals in the SignalTap GUI, but nothing was returned...
Thanks!
- 3 years ago
Yes, so as I said, why don't you just tap the right hand side signals?
sstrell
3 years agoThat's not what Analyze & Elaborate does. That first stage of the compiler simply checks all the code and builds the project hierarchy. No optimization has been performed yet. When you tap a pre-synthesis signal, the filter is showing what is tappable in the HDL code itself before any optimizations.
