amildm
Contributor
3 years agostruct -> how to add to SignalTap ?
Hi All,
Is it possible to add the struct signals to SignalTap? I did a search for the struct signals in the SignalTap GUI, but nothing was returned...
Thanks!
- 3 years ago
Yes, so as I said, why don't you just tap the right hand side signals?
amildm
Contributor
3 years agoIn my opinion, the SignalTap is built to tap nets, not signals defined in HDL. So, if two signals are assigned to the same net, the Analyze & Elaborate stage will eliminate one without leaving a choice to SignalTap at all...
