stratix10‘s power mananement and programmer
i have followed the power management userguide to set my smart VID, but i just use jtag usb blast to write my .sof to stratix10, but counter with some errors.
Device has stooped receiving configuration data
Error message received from device ...
A PMBbus error has occurred ....
i am sure i have set the VID is right in quartus panel,because sometimes i can download the .sof into the chips through the quartus programmer with jtag.
what 's going on ? how can i do to handler this?
i don't like to power off and on the stratix10 if i want to write the sof through the jtag.
1 Reply
- JohnT_Altera
HI,
May I know which particular Stratix 10 part are you using and which Quartus version are you using? May I know what is the setting used in the Power Management & VID?
Do you follow the guide from https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/ip/2019/error-18950---device-has-stopped-receiving-configuration-data---.html?
