16 years agoHi bobo,
see thread problems uploading flash memory To convert a .sof to a .flash file, use the following command in Quartus II 9.1 SP1: sof2flash --pfl --optionbit=<option bit address offset> --input=<your SOF.sof> --output=<output.flash> --offset=<desired image offset> option --pfl adds four bytes before configuration data. These bytes are used by parallel flash loader to determine wether a compressed or uncompressed bitstream is used.
