11 years ago
Stratix IV - Error 176603: cannot place node <name> at <text> because it cannot...
Hello all :)
I'm using Stratix IV (EP4SGX180KF40I3), with Quartus 11.1SP1.
I have two clock input pins: AB34 and AF6.
I would like to choose between them using a CLKCTRL instance in the design (clock MUXing).
I used the ALTCLKCTRL block from the MegaWizard, with the following configuration:
- For Global clock
- 2 clock inputs
- No enable port
- No "Ensure glitch-free switchover"
The SELECT port for the CTRLBLK was implemented with logic (could receive both '0' and '1' values).
When I run Quartus compilation, I receive the following error messages:
Error (176603): Cannot place node CLK_125M_SEC at IOPAD_X119_Y43_N0 because it cannot drive the node HDP:U1|CLK_RESET_GEN:clk_rst|CLK125M_SEL:U3|CLK125M_SEL_altclkctrl_lef:CLK125M_SEL_altclkctrl_lef_component|sd2 placed at CLKSEL_G0
Error (176603): Cannot place node CLK_125M at IOPAD_X0_Y52_N0 because it cannot drive the node HDP:U1|CLK_RESET_GEN:clk_rst|CLK125M_SEL:U3|CLK125M_SEL_altclkctrl_lef:CLK125M_SEL_altclkctrl_lef_component|sd2 placed at CLKSEL_G4
After getting the error message, I tried also to use a constant value for the SELECT ('0'), but I received again the same error.
My questions are:
- In general: Is it possible to drive these two input clock pins through a CLKCTRL block?
- Do I have anything wrong in the ALTCLKCTRL block MegaWizard configuration?
- Do I I have something wrong in the way I use the ALTCLKCTRL block?
Olga
