15 years agoHi!
Thanks. I didn't think either... yet then I don't know why the CFG DONE led doesn't light. According to the quickstart guide, even just switching on the board should lead to it lighting up (and other user-led flashing in a pattern), which it does not. May it be an hardware problem? As far as the USB blaster, I already did that (uninstall and then reinstall the driver, following the same procedure you suggest), but to no success... Thanks for the help!
