12 years agoHello again,
This is also the case for QII 12, 11 (on Windows) too. I have no clue what is the problem!! I use to have such problems in the past and I was overcoming them by fully compiling the design then run the pin assignment script, but this time it is not working anymore since the compilation cannot be successfully completed. The problem occurs by the auto-generated .qsf and therefore I am trying to check/fix it. @arisrama22: What is the board u r using?
