12 years ago --- Quote Start --- Thx for the replay The problem is that am getting this error before running the tcl script. I need to perform a correct full compilation before running the scrip in order to avoid wrong differential pairs. e.g. while I have dqs[0] and this should have dqs_n[0] as differential pair, the script is ignoring it and it is creating another one dqs[0](n) and that is creating a confect!! any ideas!? --- Quote End --- If you are using an Eval. board make sure that the .qsf file is correct for your version of design, i.e. if you are using a 230 board and the design is for a 530 board odd things may happen... S.
