Altera_ForumHonored Contributor13 years agoStratix-4 DDR3 dqs_n fitter error Hi All, I am using a Stratix-4 Dev. board and am trying to add a DDR3 UniPHY controller. All is fine until I get to the fitter which gives me the error: error (176718): pin memory_mem_...Show More
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
