13 years agoI now know that you have to run the .tcl script generated by qsys called ...pin_assignments.tcl in Quartus > tools > tcl scripts.
After that you are supposed to go to Assignment and edit the pins list to match your PCB...Xilinx does it so much simpler by letting you select a Dev. board as a template for your pins, etc. etc.
