11 years ago
Strange switch, cant justify this behaviour
I made this differentiated switch. But.. upon usage it turns out to be inverted. Contrary to what i deem to be logical behaviour?
Any thoughts?
else if (switch < register) //* so the result would be like this?
begin
action <= taken;
register <= switch;
end
else if (switch > register)
begin
register <= switch;
end
* There I would expect the switch to be greater than the register when pressed so if (switch > register) the action would be taken at the positive flank of the push button. This is not the case how come?
    It depends how your push button is wired. If it is connected so that the push button is between the pin and ground, and there is a pull-up resistor, then when you press the switch it will actually go from high to low.
    --- Quote Start ---
    --- Quote End ---
    Yes I wanted to figure that out so I attached a LED to see it it would light up. And it did. I also set the register to be 0.
    None of that had any effect..
