11 years ago --- Quote Start --- It depends how your push button is wired. If it is connected so that the push button is between the pin and ground, and there is a pull-up resistor, then when you press the switch it will actually go from high to low. --- Quote End --- Yes I wanted to figure that out so I attached a LED to see it it would light up. And it did. I also set the register to be 0. None of that had any effect..
