18 years agoHello,
You need a "feedback in datapath" anyway to hold a present state. Either as input to an "IF" MUX, or as selector for a "CASE" MUX. If you imagine that the compiler merges the two levels (if and case) at the state register input when creating the "initial netlist", the logic would be identical for both cases. Regards, Frank
