18 years agoHello Frank,
thanks for your fast reply. You aren't right. I had forgotten that it only happens in greater FSMs. In the following example I have added one signal to the state transition conditions. With else: 14 LEs, 11 Registers, fmax: 556 Mhz Without else: 15 LEs, 11 Registers, fmax: 373 Mhz I use identical synthesis and fitter options. (safe state machine encoding is off; standard one-hot encoding) You say "I would expect the two cases to produce identical gate level netlists, cause the compiler is free to minimize the logic as far as possible." - I also expect the same. But it doesn't result in the same Post-Mapping and thats the reason for this thread...
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity performancetest_1_fsm2conditions is
port(
clk : in std_logic;
reset : in std_logic;
trafficLight_ena : in std_logic;
input : in std_logic;
output : out std_logic_vector(1 downto 0)
end entity performancetest_1_fsm2conditions;
architecture performancetest of performancetest_1_fsm2conditions is
type STATES is (init, green, yellow, red);
signal state : STATES;
signal reset_timer : std_logic;
signal timer_max : std_logic;
component timer
port(
clk : in std_logic;
reset_timer : in std_logic;
timer_max : out std_logic
end component;
begin
timer1:timer
port map (
clk => clk,
reset => reset,
reset_timer => reset_timer,
timer_max => timer_max
process(clk,reset)
variable reset_timer_var : std_logic;
begin
if reset = '1' then
output <= "00";
reset_timer_var := '0';
state <= init;
elsif clk'event and clk = '1' then
if trafficLight_ena = '0' then
reset_timer_var := '1';
state <= init;
else
case state is
when init =>
output <= "00";
if trafficLight_ena = '1' then
state <= red;
end if;
when green =>
output <= "01";
if timer_max = '1' and input = '0' then
state <= yellow;
end if;
when yellow =>
output <= "10";
state <= red;
when red =>
output <= "11";
if timer_max = '1' and input = '1' then
state <= green;
end if;
end case;
end if;
reset_timer <= reset_timer_var;
end if;
end process;
end performancetest;
library ieee;
entity timer is
port(
clk : in std_logic;
end entity timer;
architecture timercnt of timer is
begin
timecnt:process(clk, reset)
variable timer : integer range 0 to 7;
begin
if reset = '1' then
timer := 0;
if reset_timer = '1' then
timer := 0;
else
timer := timer + 1;
end if;
if timer = 7 then
timer_max <= '1';
else
timer_max <= '0';
end if;
end if;
end process;
end timercnt;
