12 years agoStrange simulation results
I've been playing around with my models behavior to try and combine it into one process. However when I simulate it I am getting some odd results. Iv'e attached a jpeg of the testbench results. 1. The simulation does not work for the 1st clock cycle. 2. At time 24 ns, outputs a and f show '1'. This is during count 5, where the code states they should be at '0'. 3. At time 50 ns, reset is '1' - this should hold the process at count 0 (only c and d are '1'). However it does not happen. Could anyone shed some light onto this for me? Code is: entity seq2 is port (clk : in std_logic; enable : in std_logic; reset : in std_logic; a,b,c,d,e,f : out std_logic); end seq2; architecture behaviour of seq2 is signal count : integer range 0 to 5; signal vector : std_logic_vector (5 downto 0); begin process(clk, enable, reset) begin if reset = '1' then count <= 0; elsif falling_edge (clk) then if enable = '1' then if count < 5 then count <= count + 1; case count is when 0 => vector <= "001100"; when 1 | 5 => vector <= "011110"; when 2 | 4 => vector <= "110011"; when 3 => vector <= "100001"; end case; else count <= 0; end if; end if; end if; end process; a <= vector(5); b <= vector(4); c <= vector(3); d <= vector(2); e <= vector(1); f <= vector(0); end behaviour;
