17 years agoStrange Quartus warning with LVDS pin
I get a fitter warning regarding an automaticly placed inverted differential input pin: --- Quote Start --- Warning: DDIO pin "ADC_LVD[8](n)" cannot be placed at its location "PIN 176" because that location cannot directly feed the data-in ports of the DDIO input registers. --- Quote End --- But in the Pin-Out File, the pin has been correctly assigned. The warning already existed with Quartus V7.2 as a Critical Warning and continues with V8.1 as a regular warning. The online help gives an explanations that is obviously wrong in the present case. --- Quote Start --- CAUSE: The specified DDIO pin has been assigned to a location intended for clock I/O and must be assigned a different location. --- Quote End --- In Pin Planner tool, the differential pair also shows normal. The device is EP3C16Q240. Anyone experienced a similar behaviour? Is it a Quartus bug? Regards, Frank P.S.: I remember, that I got a similar warning with a positive LVDS pin in another design. As PIN 176, the said pin also had a CDPCLK additional function, which makes me think, it's a meaningless warning related to this pin function. The LVDS operation has been checked OK with the recent design.
