12 years agoWith the current .do file, it does assign "01" to Coin in when it should be "11".
I dont know what the problem is exactly, Im sure someone with better modelsim knowledge would know. But I do know that "force" is not a recommended way of generating test signals. It is ok for very simple setups, but when you get any form of complexity a testbench has far more control (eg read stimulus from file, log file generation, trasaction based stimulus etc, constrained random testing). If I was going to recommend anything, it would be to ditch the two process state machine style, and go with a single clocked process. It avoids latches completly as everything will have a registered output. The two process style is valid, but it's method is taught because tools many years ago would only accept this style, and the old text books linger. The single process style has been acceptable for at least 10 years.
