12 years agoThank you very much for your reply.
I'm not sure I understood - were you able to assign values other than 00 and 01 to CoinIn? Are you suggesting that the problem is caused because I used force rather than a TB? About the counter - thanks for explaining. How would you suggest implementing it then? Will moving the counting feature under the rising_edge condition work?
