12 years ago --- Quote Start --- Is there a way to define/ control the logic high/low state of FPGA output pins in this time interval? I mean, to define/ control from FPGA chip itself, not from other components on the board. --- Quote End --- It depends on the FPGA. Some FPGAs have an IO_PULLUP pin that can be used to define whether weak pull-ups are enabled or not during power on, i.e., you have a "global" option, rather than a per pin option. Generally I use pull-up or pull-down resistors on control signals that I want to guarantee have a particular state when the FPGA is not configured. Cheers, Dave
