9 years agoState Machine Viewer
Hi, I designed a state machine in my verilog codes. I evaluate it in the DE2-115 board, and everything looks good. When I opened the state machine viewer in the Quartus II 12.0, however, it sho...
9 years agoDon't know about that, but why do you mix blocking (=) and non-blocking (<=) assignments in your code?
That is really bad coding practice and can lead to numerous subtle simulation vs implementation errors. I would recommend you change all the blocking to non-blocking assignments. It may also be why the tool can't detect the state transitions, but I'm just guessing on that.
