11 years agoI am trying to write a test bench for my state machine but I don't seem to be getting the correct results.
The test bench for my state machine is the following code:library IEEE;
use IEEE.STD_LOGIC_1164.all;
-- Entity --
entity spi_statemachine_test is
generic (n: positive := 16);
end spi_statemachine_test;
-- Component declaration --
architecture behaviour of spi_statemachine_test is
component spi_statemachine
port (do_o: in std_logic_vector(n-1 downto 0);
do_valid_o: in std_logic;
di_i: out std_logic_vector(n-1 downto 0);
wren_i: out std_logic;
start: in std_logic;
rst_i: in std_logic;
clk_i: in std_logic;
correct: out std_logic);
end component;
-- Signals --
signal clk_i: std_logic;
signal start: std_logic;
signal rst_i: std_logic;
signal wren_i: std_logic;
signal di_i: std_logic_vector(n-1 downto 0);
signal do_valid_o: std_logic;
signal do_o: std_logic_vector(n-1 downto 0);
signal correct: std_logic;
-- Clock period --
constant clk_period: time := 10 ns;
-- Compomemt instantiation --
begin
C: spi_statemachine
port map(di_i => di_i,
wren_i => wren_i,
do_o => do_o,
do_valid_o => do_valid_o,
start => start,
rst_i => rst_i,
clk_i => clk_i,
correct => correct);
-- Clock --
clk_process_slave: process
begin
clk_i <= '0';
wait for clk_period/2;
clk_i <= '1';
end process clk_process_slave;
-- Stimulus --
stimulus: process is
variable data_v: std_logic_vector(n-1 downto 0);
begin
start <= '1';
rst_i <= '1';
do_valid_o <= '0';
do_o <= (others => '0');
wait for 15ns;
rst_i <= '0';
wait until wren_i'event and wren_i = '1';
data_v := di_i;
wait until clk_i'event and clk_i = '1';
do_o <= data_v;
do_valid_o <= '1';
do_valid_o <= '0';
assert correct <= '0'
report "There in an incorrect value on the output LED)"
severity error;
wait for 5ns;
wait;
end process stimulus;
end behaviour; The following screenshot is of my simulation, 'correct' should be high because the correct data is being received between 'di_i' and 'do_o'. https://www.alteraforum.com/forum/attachment.php?attachmentid=10201 Kind regards, Deadman
