11 years agoI have fixed the syntax errors and my state machine is compiling.
My state machine is the following code:library IEEE; -- Reference for VHDL source code
use IEEE.STD_LOGIC_1164.all; -- Package defined in the IEEE (Found in library IEEE)
use IEEE.numeric_std.all; -- Used to covert integer to std_logic_vector via unsigned type. Unsigned types represent postive
-- values including zero. The compiler interprets each unsigned type as a binary number, with the
-- digit of the left as the MSB (Most Significant Bit).
-- Entity declaration
entity spi_statemachine is -- Entity name.
-- Generics --
generic (n: positive := 16); -- Number of bits. Generic is used to specify parameters, for example, the length of data.
port (-- Inputs --
do_o: in std_logic_vector(n-1 downto 0); -- Data in.
do_valid_o: in std_logic; -- Check if data is valid (No data setup glitches on the data transfer), valid during one
-- clk_i rising edge.
-- Outputs --
di_i: out std_logic_vector(n-1 downto 0); -- Data out.
wren_i: out std_logic; -- Write port, valid during one clk_i rising edge.
-- Start operation --
start: in std_logic; -- Start state machine.
-- Clock operation --
rst_i: in std_logic;
clk_i: in std_logic; -- Clock synchronicity with data.
-- Output indication --
correct: out std_logic); -- Check if data transmitted is correct.
end spi_statemachine; -- End entity
-- Architecture behaviour
architecture detect of spi_statemachine is -- Identifying the architecture.
type state_type is (createData, writeData, delay, stopwriteEnable,
checkValid, compareData, checkFinished); -- Enumeration types.
-- Signals and types
signal state: state_type; -- State of the machine.
type int_array is array (integer range <>) of integer;
begin
P1: process (clk_i, rst_i, start) -- Sensitivity list. The process wakes up when an event occurs on one of the signals
-- in the sensitivity list.
-- Variables -- (Variables change immediately therefore 'rst_i' is used to stop this from happening)
variable error_rate: natural := 0; -- Incrementing error. Natural is a data type is used to represent natural
-- (nonnegative) numbers.
variable data_in: std_logic_vector(n-1 downto 0); -- Data length. Integer is a data type that represents positive and
-- negative whole numbers.
variable data_out: std_logic_vector(n-1 downto 0);
variable random_data: int_array(0 to 15);
variable count: integer := 0;
variable i: integer := 0;
begin
if rst_i = '1' then -- Reset operation used initialize all signals to predetermined state.
-- Initial values for all outputs, variables and signals --
di_i <= (others => '0');
wren_i <= '0';
correct <= '0';
error_rate := 0;
data_in := (others => '0');
data_out := (others => '0');
count := 0;
i := 0;
random_data(0) := 14492;
random_data(1) := 9335;
random_data(2) := 10648;
random_data(3) := 21153;
random_data(4) := 14657;
random_data(5) := 10583;
random_data(6) := 10651;
random_data(7) := 18398;
random_data(8) := 12598;
random_data(9) := 30086;
random_data(10) := 6444;
random_data(11) := 25436;
random_data(12) := 25025;
random_data(13) := 27533;
random_data(14) := 3525;
random_data(15) := 31968;
state <= createData;
elsif clk_i'event and clk_i = '1' then -- Signal attribute used to test for a change on a signal.
case state is
-- When state 'createData' and if 'start' equals '1', then state is 'writeData' and 'i' increments count from
-- 0 to 15. If 'i' increments count above 15 then 'i' equals 0 and otherwise state is 'createData'.
when createData =>
if (start = '1') then
state <= writeData;
i := i + 1;
if (i > 15) then
i := 0;
end if;
else
end if;
-- 'random_data' is converted into 'std_logic_vector' and is then is written in to 'data_out' and 'di_i'.
-- 'random_data' will be counted (i) up to 15 (n).
when writeData =>
data_out := std_logic_vector(to_unsigned(random_data(i), n));
di_i <= std_logic_vector(to_unsigned(random_data(i), n));
state <= delay;
when delay =>
count := count + 1;
if (count > 1) then
state <= stopwriteEnable;
wren_i <= '1'; -- Starts transmission.
count := 0;
else
state <= delay;
end if;
when stopwriteEnable =>
state <= checkValid;
-- If 'do_valid_o' equals '1' then 'do_o' gets the value of 'data_in'. 'wren_i' equals '0' as it only as
-- only equals '1' for one clock cycle.
when checkValid =>
if (do_valid_o = '1') then
data_in := do_o;
wren_i <= '0';
state <= compareData;
else
end if;
-- If 'data_in' equals 'data_out' and the error rate is below '0' then there is no error, if the error
-- rate is above '0' then there is an error.
when compareData =>
if data_in = data_out then
error_rate := error_rate - 1;
else
error_rate := error_rate + 1;
end if;
state <= checkFinished;
-- If the error rate is greater than '0' then correct equals '0', otherwise correct equals '1'.
when checkFinished =>
if (error_rate > 0) then
correct <= '0';
else
correct <= '1';
end if;
end case;
end if;
end process;
end detect; Kind regards, Deadman
