11 years agodi_i is a std_logic_vector, so to assign it to the data in variable you need to type convert it:
data_in <= to_integer( unsigned( di_i) ); And you still have the same problem that you're doing an unnecessary (and illegal) type conversion for the data_out assignment from the data variable. There are other type conversion problems. I suggest fix the syntax errors first before worry about the functionality.
