11 years agoI am still trying to write a state machine that checks to see if correct data is being received between the input 'di_i' and the output 'do_o' but I get the following error message:
Error (10409): VHDL Type Conversion error at spi_statemachine.vhd(89): converted type of object near text or symbol "std_logic_vector" must match integer type of target object
I have highlighted the error in red below. I do not know why I am getting this error message, I have set 'std_logic_vector' and 'data_out' to 16 bits. library IEEE; -- Reference for VHDL source code
use IEEE.STD_LOGIC_1164.all; -- Package defined in the IEEE (Found in library IEEE)
use IEEE.numeric_std.all; -- Used to covert integer to std_logic_vector via unsigned type.
-- Unsigned types represent postive values including zero. The compiler interprets each
-- unsigned type as a binary number, with the digit of the left as the MSB (Most Significant Bit)
-- Entity declaration
entity spi_statemachine is -- Entity name
-- Generics --
generic (n: positive := 16); -- Number of bits. Generic is used to specify parameters, for example, the
-- length of data.
port (-- Inputs --
di_i: in std_logic_vector(n-1 downto 0); -- Data in
do_valid_o: in std_logic; -- Check if data is valid (No data setup glitches on the data transfer),
-- valid during one clk_i rising edge
-- Outputs --
do_o: out std_logic_vector(n-1 downto 0); -- Data out
wren_i: out std_logic; -- Write port, valid during one clk_i rising edge
-- Start operation --
start: in std_logic; -- Start state machine
-- Clock operation --
rst_i: in std_logic;
clk_i: in std_logic; -- Clock synchronicity with data
-- Output indication --
correct: out std_logic); -- Check if data transmitted is correct
end spi_statemachine; -- End entity
-- Architecture behaviour
architecture detect of spi_statemachine is -- Identifying the architecture
type state_type is (createData, writeData, delay, writeEnable,
checkValid, compareData, checkFinished, correctData); -- Enumeration types
-- Signals
signal state: state_type; -- State of the machine
begin
P1: process (clk_i, rst_i, start) -- Sensitivity list. The process wakes up when an event occurs
-- on one of the signals in the sensitivity list.
-- Variables --
-- Variables change immediately therefore 'rst_i' is used to stop this from happening.
variable data: integer := 15; -- Data length. Integer is a data type that represents positive and negative
-- whole numbers.
variable error_rate: natural := 0; -- Incrementing error. Natural is a data type is used to represent natural
-- (nonnegative) numbers.
variable data_in: integer := 15;
variable data_out: integer := 15;
begin
if rst_i = '1' then -- Reset operation used initialize all signals to predetermined state
do_o <= (others => '0');
wren_i <= '0';
correct <= '0';
data := 15;
error_rate := 0;
state <= createData;
data_in := 15;
data_out := 15;
elsif clk_i'event and clk_i = '1' then -- Signal attribute used to test for a change on a signal
case state is
when createData =>
if (start = '1') then -- Start state machine
state <= writeData;
else
end if;
when writeData =>
data_out := std_logic_vector(to_unsigned(data, n)); -- Write data
state <= delay;
when delay =>
state <= writeEnable;
when writeEnable =>
wren_i <= '1';
state <= checkValid;
when checkValid =>
if (do_valid_o = '1') then
data_in := di_i;
wren_i <= '0';
state <= compareData;
else
end if;
when compareData =>
if data_in = data_out then
error_rate := error_rate-1;
else
error_rate := error_rate+1;
state <= checkFinished;
end if;
when checkFinished =>
if (error_rate > 0) then
correct <= '0';
else
correct <= '1';
end if;
end case;
end if;
end process;
end detect; Kind regards, Deadman
