11 years agoStandard " Interface to User Logic" in Qsys Component Editor
I changed to Q13.0 from Q7.1 (also from Sopc to Qsys) just right now, then I are struggling many difficulties.
But the first thing is I need an "Interface to User Logic" to control some devices, which is "..\sopc\legacy components\interface to user logic". I tried to build it in Qsys Component Editor, but I'm not sure if it's correct? The attached pictures and codes are listed You're very kind if can give any advice. // /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// `timescale 1 ps / 1 ns module bus32bits ( input clk, // clock.clk input resetn, // reset.reset input [9:0] address, // s0.address input read, // .read output reg [31:0] readdata, // .readdata input write, // .write input [31:0] writedata, // .writedata input chipselect, // .chipselect output [9:0] bus_add, // conduit_end.export output bus_read, // .export output bus_chipselect, // .export input [31:0] bus_rd_data, // .export output bus_write, // .export output reg [31:0] bus_wr_data // .export ); assign bus_write=write; assign bus_read=read; assign bus_add=address; always@(posedge clk) if(!resetn) bus_wr_data<= 32'b0; else begin bus_wr_data=(write&&chipselect)?writedata:32'hzz; readdata=(read&&chipselect)?bus_rd_data:32'hzz; end endmodule // /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// The interface should be like that. https://www.alteraforum.com/forum/attachment.php?attachmentid=9173 component editor signal https://www.alteraforum.com/forum/attachment.php?attachmentid=9174
