STA failed during rapid recompilation
- 5 years ago
I was able to reproduce your problem in Quartus Standard version 15.1.2, but not in the later versions. Unfortunately our engineering team does not support Quartus Standard version 15.1.2 anymore so I cannot report this problem to them.
I suggest you migrate to Quartus Standard v19.1 as the error does not arise in this version. This is the latest version of Quartus Standard that still support OpenCL. Also since you're using ALTERAOCLSDKROOT in your design it needs to be changed to INTELFPGAOCLSDKROOT as it has been upgraded in v19.1.
Nurina
Hi Mingqiang,
We did not receive any response to the previous question/reply/answer provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
PS: If you find any comment from the community or Intel Support to be helpful, feel free to give Kudos.
- cosx5 years ago
Hi Nurina,
Sorry for the late reply as I just graduated from university and was having a trip.
Thank you very much for your and since the problem is not supported, I would probably change to a modern version of compiler.
Best Wishes,
Mingqiang
