11 years agoSRAM constraints
Please help to constrain the following schema (see picture):
DataOut pin is a positive pulse of 10 ns, WE signal is a negative pulse of 7.5 ns. External device latches signal from DataOut pin by rising edge of WE pin (like a SRAM). Relationship between WE and DataOut at the external device side is: tsu = 4.9 ns, th = 0.1 ns. In my poject I create shifted clock using PLL and create WE signal by "nand" of triggers, latching "enable" signal with this clock and main clock. http://www.alteraforum.com/forum/attachment.php?attachmentid=10121&stc=1 At this time my sdc is: create_clock -name {ClkIn} -period 10.000 -waveform { 0.000 5.00 } [get_ports {ClkIn}] derive_pll_clocks create_generated_clock -name ClkWE -source [get_nets {inst|altpll_component|_clk0}] -duty_cycle 75 -offset 2 set_output_delay -clock [get_clocks {ClkWE}] -max 4.9 [get_ports {DataOut}] set_output_delay -clock [get_clocks {ClkWE}] -min -0.1 [get_ports {DataOut}] I do not know how to tell timequest, that WE is generated from two clocks with phase shift set in PLL settings. Now changing PLL settings does not affect analysis. Thank you.
