9 years agosplitting an output bus on a symbol
Good morning, This is for a project for school and I'm pulling my hair out trying to figure out why I have no sign on life on my board. I have all components working individually (verified usin...
9 years agoThanks for the reply!
I think you're right that the connections aren't the trouble. I removed the mod-5 counter and connected lights directly into the frequency divider and still got nothing. teI have a frequency divider going into that mod 5 counter. TIMR should be high every 5 cycles and then go back to low on the next clock cycle. As I typed that out, I need to check that my code actually has TIMR set low on the next clock cycle, otherwise it just stays high forever. That might actually be the problem. Sometimes it helps to just talk it out! And thank you for suggesting the scope! I was wondering how to sort out waves without a simulation. That works brilliantly!
