13 years agoJust a quick correction. All versions of Modelsim/Questa above Modelsim PE run as the same speed if you have all available optimizations on.
You should be able to log signals to a file at the beginning of the simulation add the to the wave window at the end of simulation and then scroll back to see waveform throughout the simulation.
