10 years agoSpecifying global memory buffer location for Nallatech P385 D5
Hi, I would like to specify global memory as on-chip RAM of Nallatech P385 D5 board. According to the instruction of the Programming Guide (Section "Specifying Buffer Location in Global Memory...
10 years agoHi,
You would need to create a custom BSP to add a BRAM global memory buffer so it is accessible directly from the host (a new board_spec.xml file will not be enough). The FPGA BRAM resources are used by the OpenCL SDK compiler, just not as a global memory buffer. The flow of developing custom BSP is described here: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/opencl-sdk/ug_aocl_custom_platform_toolkit.pdf G
