12 years ago --- Quote Start --- Are my constraints below correct? create_clock -period 4.0 -name pclk [get_ports pclk] derive_pll_clocks derive_clock_uncertainty # Create virtual clock for TIUSB1310A create_clock -period 4.0 -name pclk_ext set_input_delay -clock pclk_ext -max 2 [get_ports {rx_data [*]}] set_input_delay -clock pclk_ext -min 1 [get_ports {rx_data [*]}] --- Quote End --- That looks ok to me. Other signals apart from data as per your diagram also require same delay figures. clock uncertainty can be entered from your chip data sheet if available
