15 years agoSOPC problem using Avalon-MM tristate bridge and memory
I'd like have some memory in my design that is on-chip (dual port) but outside the SOPC so that I can connect to the second port. This looks possible when I add an Avalon-MM tristate bridge and an ID...
9 years agohi this is imran
can anyone help me for the following. if i run a project in c code in eclipse as nios II hardware then i get the following error message."Project does have an ELF file. Please make sure project has been built successfully"
