15 years agoSOPC problem using Avalon-MM tristate bridge and memory
I'd like have some memory in my design that is on-chip (dual port) but outside the SOPC so that I can connect to the second port. This looks possible when I add an Avalon-MM tristate bridge and an ID...
11 years agohi this is imran.
can anyone help me for the following. if i use onchip memory then error flashes as follows. pls help regarding usage of onchip memory in accordance with hello world program in c. if i need to use sram too then pls help for the same too.
