15 years agoSOPC problem using Avalon-MM tristate bridge and memory
I'd like have some memory in my design that is on-chip (dual port) but outside the SOPC so that I can connect to the second port. This looks possible when I add an Avalon-MM tristate bridge and an ID...
15 years agoI've defined a custom synchronous SRAM and that seems to work. It's a bit clunky because the data bus comes out of the SOPC block as a bidirectional bus, but it seems to work.
